Вместо PowerCommandera?
ньюби
На форуме: 19 Лет 9 Месяцев 15 дней
#1 Сообщение ньюби »
Кто с такой штукой знаком?
Active Timing Retard Eliminator (ATRE)
I bought my ATRE from SJL Products, Inc. Here is a blub lifted from the website on the advantages or the
ATRE.
Programmable - user selectable option of which gears to re-map (Re-Map 1st & 2nd / 1st, 2nd & 3rd / 1st, 2nd, 3rd & 4th / All Gears)
Programmable - user selectable option of which map to use (choose between 4th gear, 5th gear and 6th gear map)
Overcomes the OEM speed limiter on 2001 Hayabusa's when set to 5th gear map
Untouched neutral map results in a smooth idle and cooler motor temps than simple TRE's
Visual Indicators - Power and Status
Fail-Safe Mode - reverts to OEM settings
Suzuki OEM connectors - no cutting of harness required
Low current consumption - max. 60mA
Over-Voltage and current protection
Epoxy protection - humidity and vibration resistant
Surface Mount Electronics used
Small size, fits easily under body work - Dimensions: 74mm x 49.5mm x 25.4mm
Only a few minutes required for changing of settings - ideal for drag-strip
НЕ НАДО БОЯЦЦО!
